Materials - Revit for student
37 REPLIES 37
Message 1 of 38
1541 Views, 37 Replies
Good morning, sorry for the trouble but I would have a question.
I've downloaded the version for Revit students recently but when I try to go to materials to modify them I do not do it; is it a limitation for students or is there something wrong?
Thank you so much to anyone who will respond
37 REPLIES 37
Message 2 of 38
-FDC-
Something is wrong.
What version did you download ?
Check the autocad desktop app if there are any updates.
Can you post a screenshot so I can understand the problem ?
Message 3 of 38
Stanis-74
recently i`ve had same problem, but it was with buttons of family panels.
try replace your file to other derectoriy. or check box "read only" in your file options.
Message 4 of 38
in reply to: -FDC-
I installed Revit 2018.
I did a photo of the files that I installed; I do not know how to get the picture of the problem because when I try to press on the material button it does not do anything so i do not know how to make you see
Message 5 of 38
in reply to: Stanis-74
thanks for your advice  but I tried to press everything ... nothing to do 😞  I think I will try to install it again
Message 6 of 38
Stanis-74
Message 7 of 38
Thanks for the photo but even if I do the steps you have shown me, after pressing on the "ball" materials I will not leave the screen that came out with you with all the materials; it's as if the material library did not exist
Message 8 of 38
Stanis-74
did you create a project ?
Message 9 of 38
Yes
Message 10 of 38
-FDC-
What graphics card do you have and did you install the latest drivers?
Message 11 of 38
Stanis-74
find same problem here: https://www.youtube.com/watch?v=lPpd6G5JIMs
the autor has fix the problem by uinstal and instal libraly pack
Message 12 of 38
in reply to: -FDC-
my mount NVIDIA GEFORCE 610M, I did upgrade 2 days ago
Message 13 of 38
my pc*
Message 14 of 38
-FDC-
You also installed the latest nvidia drivers ?
Message 15 of 38
-FDC-
If you are sure you have the latest nvidia drivers try the autodesk desktop app to see if there are any updates you don't have.
If you don't have it try this link:
www.autodesk.com/ada-installer
Message 16 of 38
-FDC-
If all this dosn't help try installing the latest .NET framework.
See this link:
https://forums.autodesk.com/t5/installation-licensing/windows-7-8-1-10-updates-microsoft-net-framewo...
Message 17 of 38
in reply to: -FDC-
I tried the link you sent me but says I already have the most up-to-date version, I no longer know how to try it I uninstalled and installed everything. Can not you send me the downloaded file? maybe I finally get the materials.
Message 18 of 38
-FDC-
Is it revit 2018 or 2018.2 ?
Message 19 of 38
in reply to: -FDC-
is Revit 2018.2
Message 20 of 38
-FDC-
Latest .NET framework and latest nvidia installed?
Maybe you can try it with disabled hardware acceleration.
