materials are not showing
elifaslikayaKKLLM
Observer Observer
elifaslikayaKKLLM
Observer
Observer
I made a family and give it a material and pattern. But when I load it into project materials aren not showing up. I tried the fix it on the object styles but didn't worked. Probebly I made it wrong but can't fix the problem.
Post the family file here.
vitorbortoncello
Add a material parameter in the family and assign it to the desired family elements, so then, when you load the family in the project, you can customize the material parameter in the project space.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @elifaslikayaKKLLM
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
