Insert AutoCAD file with OLE object in Revit
7 ANTWORTEN 7
Nachricht 1 von 8
r_lujanski707
477 Aufrufe, 7 Antworten
Hi, when I export AutoCAD from Revit and sent this file to client I lose images. I must every time send this AutoCAD file with images. Instead of this I want to send only one dwg file. Using PASTESPEC function in AutoCAD I inserted image and after then there is no reference between image and dwg file. But when I insert this AutoCAD file in Revit this image is removed. Is there any way to send only AutoCAD file without losing images?
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: r_lujanski707
ETRANSMIT.
Nachricht 3 von 8
r_lujanski707
How can I use it?
Nachricht 4 von 8
Nachricht 5 von 8
r_lujanski707
als Antwort auf: barthbradley
As I understand using this function you can send the whole folder with attached images. But when I export AutoCAD from revit that has images, these images automatically appear with AutoCAD file and have reference. Is it possible to export dwg file without these images? Can I convert these images and insert them in revit directly so that when I export AutoCAD these "images" don't appear?
Nachricht 6 von 8
DiRoots Pro sheet can export DWG with OLE.
Nachricht 7 von 8
r_lujanski707
als Antwort auf: ToanDN
I have sheets in revit and I must export these sheet's in AutoCAD. But when I export dwg file images automatically are exported (have reference with exported dwg files). As I now OLE objects don't have reference with dg files. But I can't insert AutoCAD file with OLE object in revit's sheet. After then this OLE object disappears in revit. How can I insert images or dwg file with images so that when I export sheets there are no any images with exported AutoCAD? Is it possible?
Nachricht 8 von 8
r_lujanski707
I have sheets in revit and I must export these sheet's in AutoCAD. But when I export dwg file images automatically are exported. As I now OLE objects don't have reference with dwg files. But I can't insert AutoCAD file with OLE object in revit's sheet. After then this OLE object disappears in revit. How can I insert images or dwg file with images so that when I export sheets there are no any images with exported AutoCAD? Is it possible?
