I made a family and give it a material and pattern. But when I load it into project materials aren not showing up. I tried the fix it on the object styles but didn't worked. Probebly I made it wrong but can't fix the problem.
Solved by handjonathan. Go to Solution.
Solved by vitorbortoncello. Go to Solution.
Hi @elifaslikayaKKLLM
Thanks a lot for posting your question to the forums! Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
