MATERIAL TAKEOFF
5 REPLIES 5
muhammadhammadcivileng
296 Views, 5 Replies
MATERIAL TAKEOFF
 revit used centre to centre spacing for wall length calculation which leads to doubling of length for intermediate walls how to deal with for correct quantity takeoff??
5 REPLIES 5
when drawing a wall, select disallow join so it ends at the right spot:
or just right click the blue point at the end of the wall and select the same:
Also, Revit 2025 has new features to more quickly allow and disallow joins
I don't understand. Got pictures?
Create Parts from Walls and then create Parts MTO.  Problem solved.
There is no real solution. Proposed solutions do solve the issue but require A LOT of manual work if we're talking about a real building, almost impossible for anything more than three walls.
Since it's standard in my country to increase materials by 5% (for some items even more), we just forget that Revit calculates it wrong (it does it for several more things) and live with it ¯\_(ツ)_/¯
Jazakullah(thanks) to all of you for your time ..it was done with the disallow joints
Forma Design Contest
