MATERIAL PATTERN NOT SHOWING IN MODEL-IN-PLACE FAMILY
jledgewood409
jledgewood409
I have created a model-in-place family that consists of two extrusions. on extrusion A i have applied a material that has a surface pattern. the pattern shows while in 3D and while in the edit family mode. when i am in an elevation the pattern does not show.
Post the file.
Are you sure your Elevation View is not cutting through the Element?
jledgewood409
I BELIEVE I WAS ABLE TO EXTRACT THE MODEL-IN-PLACE FAMILY INTO ITS OWN FILE. SEE ATTACHED
jledgewood409
IT DID NOT APPEAR TO BE CUTTING THROUGH THE ELEMENT. BUT TO BE SURE I CREATED A CUT PATTERN AND IT DID NOT SHOW UP.
Screen Hatch shows in Elevation here.
