hidden elements in 3D view
5 ANTWORTEN 5
Nachricht 1 von 6
NERDASORUS
632 Aufrufe, 5 Antworten
Hello
As the title suggests, i have various elements that are not showing in 3D view (like for example: connection plate for the steel columns, the grooves in the sandwich panels) but when i toggle the "reveal hidden elements" they show up as you can see in the attached pictures. Neither element/category is hidden!
5 ANTWORTEN 5
Nachricht 2 von 6
WEC17
als Antwort auf: NERDASORUS
Did you check you Visibility Graphics in your 3D view? Check if you have Structural Connection check
Nachricht 3 von 6
Select those hidden elements and look on the contextual tab for unhiding options.
...those look like Analytical Nodes from here.
Nachricht 4 von 6
NERDASORUS
als Antwort auf: barthbradley
Thanks for your reply
im not talking about the nodes, what i want is the vertical lines on the walls
Nachricht 5 von 6
NERDASORUS
als Antwort auf: WEC17
thank you for your answer, this actually solved the connection part!
Nachricht 6 von 6
Looks like everything but the Analytical Elements are visible in the Right View.
