Hello there.
Id like to know if its possible to assign IFC parameters to a topography created in Revit - Custom parameters to read out material and different text, True / False parameter etz.
If is there a workaround for it or a plug in I could use?
Im exporting it to IFC to be useable in ArchiCAD
And second thing what I would need to do is assign a own IFC parameter to a family:
It needs to read it out when imported into Archicad as:
Pset_BuildingElementProxySpecific with the name XY and different parameters like Text, True/false etz
I did set up the parameter in the Family itself but the export doesnt seem to work so Id assume there might be a trick to exporting it.
Really appreciate your kind help! Thank you for any kind of answer!
