Material of nested family
zs-17
Message 1 of 17
zs-17
Hi
I create a table with a nested chair family. The chair has material parametric. I want to control its material from my project. How to do it please.
Regards
Accepted solutions (3)
Replies (16)
Message 2 of 17
Assign a Material Parameter to the Geometry in the Family and then you can assign a Project Material to that Parameter inside the Project.
Message 3 of 17
zs-17
  1. (Assign a Material Parameter to the Geometry in the Family) I know how to do this part and I think you mean to do this into Chair family?
  2. (assign a Project Material to that Parameter inside the Project) I don't know how to do it. Can you show me how please?
Regards
Message 4 of 17
Select the family and find its Material Parameter in its Properties. Change it.
Message 5 of 17
zs-17
The Chair Family already has a Shared Parameter for material
Message 6 of 17
zs-17
In the project, I can find only the material properties for the table I created. But no material properties for the chair.
Message 7 of 17
Is the nested family a Shared Family?  If it is, then tab-select on the Family is the Project to select and change the Material Parameter value of the Chair. Alternatively, you can Associate the Nested Chair Material Parameter to a Material Parameter in the Host Family.  Now that Host Parameter will drive the Material Parameter of the Nested Family inside the Host Family/Project.
Post the Family. I'll fix 'er up for you.
Message 8 of 17
zs-17
I will be more than happy if you can show me how to do it. Because I want to learn it.
Many Thanks
Message 9 of 17
Set the chair family to shared.
Message 10 of 17
zs-17
Material 1 is Family parameter if I change it to Shared, the OK button will not be available. Both Material main and secondary are Shared parameters. In the end, I need step by step or illustrations or a tutorial link on how to do it, please. Because this is the best way for me to understand it.
Many thanks
Message 11 of 17
Go into Type Properties of "Z_Parametric_Aquarium_Table" Family" in attached Project and see the 3 Material Parameters for Chair Seat, Back and Legs. Assign whatever Project Material you  like to them.
Message 12 of 17
zs-17
Hi
Ok. It's working. I'm grateful. But I still miss a step here How to associate the material of nested family in a host family 🤗
Thank you
Message 13 of 17
bin
No, you can't.
Message 14 of 17
Message 15 of 17
zs-17
Many Thanks
Message 16 of 17
@zs-17: Can you mark the "Accepted Solution" please? That is, acknowledge the person/post/information that actually helped you to resolve your issue.   That makes us that help feel good.   😉
Message 17 of 17
zs-17
Yes. I'm sorry. I forgot to close the post. 🙄
