massing and such
8 REPLIES 8
Message 1 of 9
jfjacques
612 Views, 8 Replies
massing and such
So all I want to do is create a shape and extrude it. Lets say its a square with three "negative" squares in it. Imagine a wall with 3 windows.
Is there no way of doing this with one massing?
I create a positive shape but I have to create negative one as well....a waste of time considering every other software would extrude nested loops, but ok. Then I find out I can't actually have more than one negative shape per positive form.....What am I missing?
8 REPLIES 8
Message 2 of 9
in reply to: jfjacques
Not with massing but with a normal extrusion yes. You can draw multiple non-intersecting loops and make them one extrusion.
Message 3 of 9
Massing in Revit is terrible indeed, but you can add more than one void per solid.
Show us a picture of what you are trying to do.
Also give this idea a vote! It's about updating/finishing the development of massing tools.
https://forums.autodesk.com/t5/revit-ideas/revisit-massing-and-panel-tools-give-them-some-love/idi-p...
Message 4 of 9
jfjacques
OMFG! I never knew about extrude! I always just massed.
This begs the question. What's the point of massing exactly? I figure it's to move from mass to revit system families, but this rarely works. Also why can't I just extrude and then convert the result to system families. Whoever came up with voids needs to be shot.  It's called Boolean Operations and it needs about 100 X more functionality.
Yup went ahead and voted.
Message 5 of 9
jfjacques
hmm can't seem to find extrusion... where is it? Weird.
Message 6 of 9
If you're asking thee kinds of questions, its likely because you have not done any research about how massing works. Please follow a tutorial in a video or book and then come back after learning a bit. It does not work like the rest of Revit or regular modelling.
Good luck.
Message 7 of 9
Any model family that is not Mass or Adaptive, such as Generic Models, Casework, Doors, etc.. and in-place family as well.
Message 8 of 9
jfjacques
ah components...model in place?
Message 9 of 9
Massing is done to do conceptual forms of building that are then populated with panels. It seems like you are trying to make a family.
I think you need to step back a bit and go back to basics of family creation. I think you went too far by going into massing. You took a wrong turn somewhere! 😮
Forma Design Contest
