Mass In Place- Divided Surface
tykN3JLE
tykN3JLE
Hi there!
I'm trying to make a Herringbone pattern for floor slab. I'm not using .PAT pattern because I can't seem to make it visible in Navisworks
It seems the lines are visible if its from divided surface of Mass In Place.
Is there a way to create a custom shape for Divided surface?
I was thinking of creating one family as the brick and insert it into the divided surface.
Thanks!
tykN3JLE
I managed to do this by using the Rectangle Divided Surface
But how do I make it so that the mass in place follows a topography surface?
Export the Toposurface to DWG and then insert the DWG into an In-Place Massing environment.  Might work. Might not.  Depends on how triangulated the surface is.
tykN3JLE
Too triangulated, sadly.
Any other recommendations of ways to model the pavement with Herringbone pattern?
Create a floor or roof for your pavement.  Assign a material with the surface pattern to it.  Export it to 3d DWG and link it back in an in place family in a 3d view ( or uncheck current view only).
