Hi
I would like to be able to have a type parameter for the angle cut of beam end
I only found two ways to do it, but none of them are exactly what I need.
One is using a reference plane which works only as an instance feature. The other way is using an Opening by Face but I haven`t managed to create an angular dimension parameter in the Sketch mode of the opening profile
It doesn`t let me.
Is there a better way or can it be done with just Reference planes?
I cannot create a reference line at a side plane inside the the family. It only lets me pick front and end planes.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
UPDATE
I found I can in fact create an angled reference line and use a void cut inside the family but how can I lock the void extrusion sketch to the reference line?
I managed to do it without reference lines, just constraining the angle of the sketch. But even though I have created a new type, now both types have the End Angle parameter.
If I delete the void from one of them, its deleted from both types.
Why don't you use OOTB Beams (e.g. Structural Framing) and cut them in the Project using Cope tool or cutting back to Ref. Plane? Be a lot easier in the long run.
