Mask region not masking in family when loaded
XXalessio.amodioXX
Message 1 of 16
XXalessio.amodioXX
Hi all,
I have to mask a a connection within the family but when i loaded it into the project the mask region is not asking what it should. Any ideas?
Replies (15)
Message 2 of 16
dzanta
i would try the following:
- ensure masking region is on a plane that is above the object being masked
- upload the family so we can look at it and play with it
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 16
Turn on Hidden View.  Maybe you're in Wireframe.
Message 4 of 16
dferreira-blackwell
Can you upload the family, please?
Message 5 of 16
XXalessio.amodioXX
Hi ,
Here you have the project .
Message 6 of 16
XXalessio.amodioXX
HI,
Masking region is on plane, I have upload the project.
Message 7 of 16
XXalessio.amodioXX
HI,
View in project is set in hidden line.
Message 8 of 16
  1. In Plan View, place a Vertical Ref Plane on the Right Side of the two geometries in the View, and then name the Ref Plane.  NOTE: Make sure to draw the Ref Plane slightly offset from the geometry.
  2. In Right Elevation View, Set the Current Workplane to the Named Ref. Plane you just created above.
  3. Draw your Mask Region on that name Ref. Plane, and then uncheck "Draw in Foreground".
  4. Load into Project. Masking Region now fully covers elements behind it.
Read this to understand more about method used:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 9 of 16
XXalessio.amodioXX
Nice call the trick  Ref Plane slightly offset from the geometry.
Message 10 of 16
trodriguez1
The masking regions do not hide annotation lines, is there a way to fix this problem? Generic annotations will mask, but not when inserted into a model category family.
Message 11 of 16
ljohnson_OCI
Community Visitor
Community Visitor
Did you ever get a solution to this problem or find a work around?
Message 12 of 16
ConstantineC
I just had similar issue. I had to create a new ref plane on offset it above an extrusion geometry of a simple cabinet.
I created a void cut to show the door gap in 3D but I did`n want it to appear in floorplan.
Why is this necessary since the Masking region was already set to Draw in Foreground?
I think it sometimes works?
Message 13 of 16
ConstantineC
Unfortunately I just loaded the family in the project and the masking does`nt work
Message 14 of 16
ConstantineC
Does anyone know whats the issue with the masking ?
I have it set to another reference plane on top of the 3D. It does mask inside the family but not in the project
Message 15 of 16
ConstantineC
Nevermind, I just realized its because of the Cutplane. The cabinet was 2.8 meters tall.
I just hid the extrusion in the Plan view and now it only shows the detail.
Message 16 of 16
aquevedo
Thank you this fixed my issue!
