What is the best, quickest, simplest way to set up a schedule to specify weather it is a 1 Bed or 2 Bed apartment. Any suggestions welcome.
If you're apartments are groups you can schedule those groups (since Revit 2018).
If they're not, you could add a project parameter to the rooms for the apartment type (or you could use the 'out of the box' parameter called 'department').
Another way would be to use area plans.
@wr.marshall wrote:What is the best, quickest, simplest way to set up a schedule to specify weather it is a 1 Bed or 2 Bed apartment. Any suggestions welcome.
This is a really vague question. Can you be more more specific? What do you mean by "set up" a schedule? What kind of schedule? And "specify" how? What input and variables are being used/evaluted? What Parameter Fields are available to sort, filter and group by? Etc.
What is 'it'?
