Making two extreme dimensions equal
In a situation like below, is it possible to automatically make the extreme dimensions equal while preserving the middle one?
Hi @Anonymous,
here you are:
http://forums.augi.com/showthread.php?70047-Non-adjacent-EQ-Dimensions
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Want to present in Infraworks? Vote this up!
Thank you for replying and for the link. Altough I cannot get how can this help in my case. What I want is not replacing the extreme dimension values with "EQ" but rather automatically moving the extreme walls so that the distances are equal.
Not directly, but you can do it by entering the formula for the dim.
... or using an intermediate reference.
Thank you. Although it is not what I've dreamed of, I understand this is the best we can get in Revit. Therefore I will mark your answer as a solution.
Sahay_R
Super neat trick, @ToanDN - learned something new today!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
