Every time I attempt to copy a text note from an enlarged plan to a detail view, the text comes in rotated. We can always rotate the text to correct it, but I would be interested in knowing why this happens. Thank you!
I don't think so. I have tried to match properties between viewports and crop areas too - to no avail. The Detail view is a drafting view.
I understand when copy and paste text notes from enlarged plan to detail view the resulting text is rotated. I unable to recreate this. I wonder if you could respond to the follwoing:
1. What version of Revit are you using?
2. What scale are the drawing you are copying from to to?
3. If you open an out of the box Revit file, add a text note in Level 1 (set to the scale in your project), create a new drafting view (also set to the scale in your project), copy the text and paste it, what happens? If anything other that what's expected I will need the file.
4. If you cannot recreate this in a new file is this only happening in your file?
Thanks for posting.
Hi Alan!
Apologies for the tardy response. To answer your questions -
1) This project is in Revit 2016
2) Copying text from a 1/4" scale elevation detail to a 1 1/2" scale plan detail
3) When I replicated this situation on a new project created with the same template, things worked perfectly. The note came in exactly as it was supposed to.
4) This issue is only happening in this one file. Never seen this happen before.
Again, thank you for your response! As always, appreciate the help!
Rina
