Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Making an Electrical system
18 REPLIES 18
Message 1 of 19
613 Views, 18 Replies
Good Morning,
My firm is an Arch/eng collaboration.  We recently created an Architectural template in Revit 2014 and we are trying to have all trades work in a single model.  Everything has worked out very well, with ALOT of communication. but when it comes to electrical we cannot set up a system. There is no way that you can insert or load, to any of our knowedge, a panel schedule.  Without a panel schedule you cannot create and curcuitry and hence no Electrical system.
I have looked through alot of these forums and found that if you have a preium design suite it should be possible.  Does anybody know the process for making it work.  Thank you.
18 REPLIES 18
Message 2 of 19
dzanta
there is no panel schedule as you normally think in Revit.  There are Panel schedule templates (default) to use.  Insert a panel, then select it.  In the contextual tab, choose create panel schedule.  This will make revit create a panel schedule based upon the default panel schedule.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 19
in reply to: dzanta
Thank you Danz Ta,
That allows me to have a panel schedule, but I still cannot chose a panel for my circuits to propagate the panel schedule
Message 4 of 19
dzanta
you need to create your electrical system (i.e. light system) first.
once created, you can assign the system to that actual panel.
the panel schedule will propogate with data afterwards
Message 5 of 19
in reply to: dzanta
I have already created the Electrical System, but when I select a Panel, there is no panels in the dropdown dialog box.  All the panels are set to the correct voltage, as well as the electrical and lighting fixtures.
Message 6 of 19
dzanta
strange...if there are electrical panel families already loaded and inserted somewhere in your revit project, it should show up in the list of available panels to choose from unless it is already assigned to a different system.  Double check by using the System Browser Panel (View Tab, User Interface, check System Browser)
Message 7 of 19
in reply to: dzanta
Everything is in a system, but none assigned it's weird. I even took out everything and used basic Revit Families after a purge. Looks like I'm doing it in excel. Lol
Message 8 of 19
dzanta
can you send me the revit file so I can look at it?
Message 9 of 19
in reply to: dzanta
it will not allow me to email or post, the file is too big.  I sent you a link to dropbox
Message 10 of 19
dzanta
if you give me your email address, I can send you a link to my dropbox temp folder.
Message 11 of 19
in reply to: dzanta
jdkillian@wdgnola.com
Message 12 of 19
dzanta
in reply to: dzanta
link sent...
Message 13 of 19
in reply to: dzanta
I have it uploaded
Message 14 of 19
dzanta
in reply to: dzanta
i have your revit model open, what electrical system do you want me to look at and what electrical panel do you want me to look at to ensure the system is created properly so I can tie the electrical panel back to it?
I am running revit 2016 fyi.
Message 15 of 19
in reply to: dzanta
Either the lighting to LDP, or the receptacles to LDP.  Both do not work, but I figure they both have the same issue. I only have up to Revit 2015, and the job is in 2014.
Message 16 of 19
dzanta
in reply to: dzanta
The reason you cannot create a system and tie it back to the electrical panel is because the voltage on the panel does not match the distribution system.  Once this is changed, you can assign the electrical panel to the distribution system you want.  After that, you can assign the electrical panel to the light fixture system.
Message 17 of 19
dzanta
in reply to: dzanta
you will also need to make sure that the connector on the panel can accommodate the distribution system you created.
Message 18 of 19
in reply to: dzanta
It's working now.  It would not let me create a distribution system yesterday.  I guess you cannot do it until you you adjust the power connection.  I thought they were already set in the family. I did not know i had to go into the family and adjust them before I can make a distribution system.
Thank you very much for your help, I greatly appreciate it.
Message 19 of 19
dzanta
anytime
