07:40 AM
Good Morning,
My firm is an Arch/eng collaboration. We recently created an Architectural template in Revit 2014 and we are trying to have all trades work in a single model. Everything has worked out very well, with ALOT of communication. but when it comes to electrical we cannot set up a system. There is no way that you can insert or load, to any of our knowedge, a panel schedule. Without a panel schedule you cannot create and curcuitry and hence no Electrical system.
I have looked through alot of these forums and found that if you have a preium design suite it should be possible. Does anybody know the process for making it work. Thank you.
Link copied
