Making a second window frame invisible in other family type
jens_lathouwers
jens_lathouwers
Hi all,
I'm trying to model a windows family which has two family types:
one fixed
one opening
for the opening frame i want to add a frame within the original frame as windows are build. I can't seem to figure out  how to make the second frame only visible in the fixed family type.
Could anyone send me the right way?
Create a Yes/No type parameter and assign it to the frame. Turn On for the type that it shows and Off for the type that it does not.
See attached 2019 family.
https://knowledge.autodesk.com/community/screencast/deff387e-8c66-4396-8972-80a9c94a749e
Screencast will be displayed here after you click Post.
A couple of Yes/No parameters are needed. One that is associated to the geometry's visibility parameter and the other that is controls whether it is checked or unchecked.
First Yes/No Parameter named "Fixed"
Second Yes/No Parameter named something like "Geometry's Visibility". This one is driven by Formula "=Fixed".
When "Fixed" is checked, "Geometry Visibility" will be automatically checked. When "Fixed" is unchecked". "Geometry Visibility" will be automatically unchecked.
