Create View/Elevation Marker for Sim. Views
Message 1 of 11
I have two offices (Office 1 and Office 2) that are the same but mirrored. I currently have an Elevation marker with view A and B showing North and South walls of the office. How do I create an Elevation marker to say A Sim. and B Sim. referring to views A and B from Office 1. I will not be creating elevation views for A Sim. and B Sim. They are strictly for plan view.
Replies (10)
Message 2 of 11
Are you meaning you want two types with two different Reference Labels?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Message 3 of 11
- create a true elevation for Office A, the mark will not show SIM
- create elevation and choose reference other view for Office B, then pick the Office A elevation view form the list, the mark will show SIM
Message 4 of 11
Unfortunately, when I select the view, the option to Reference another view is greyed out and I am not able to do that
Message 5 of 11
You have to check that right after you start the elevation view command, before you drop it on the plan.  See screencast.
https://knowledge.autodesk.com/community/screencast/1953556d-90e5-4953-bda2-c06899c53fb9
Message 6 of 11
Create the View and select Reference  Another View.
Message 7 of 11
Ah ha!! Thank you.
Message 8 of 11
Okay. Tried doing that but I do not get the 'SIM.' to show up.... The view I am referencing has been in the file for some time now. Could it be because it was not recently created and has already been placed onto a sheet?
Message 9 of 11
Maybe the SIM label is deleted or Invisible in the Elevation Pointer family. Check it.
Message 10 of 11
Are you still having issues? Would a Screencast help?  https://www.youtube.com/watch?v=n6d0W7go4DQ
Message 11 of 11
benlD8AW8
How would you get "Sim" to show up when placing a section marker in a drafting view that's referencing another drafting view?
