Thin join of roof and wall
ar999ar
Message 1 of 10
ar999ar
Dear friends,
Is there any way to connect wall to roof exposing only thin line of roofing material without any Soffit and Fascia?  Drawing No. 3 (not 1 or 2) in attached picture.
I have tried manipulating Core Boundary and Function Number in Wall’s and Roof’s structures. No luck...
Revit 2018.2
Thank you
Replies (9)
Message 2 of 10
I'm not sure what you mean. Do you want to wrap the roof edge with the wall finish materials?
...I think I get it. You'll need two roofs to do this -- and wall will attach to upper roof (via Attach Top/Base tool).
Message 3 of 10
ar999ar
Yes, to wrap is also right description
Message 4 of 10
See attached.
Message 5 of 10
Not wrap. Meet underside of roof. I was thinking you meant to wanted the wall finish to wrap all around the eave (e.g. soffit and fascia).
Message 6 of 10
ar999ar
Picture looks exactly what I'm looking for.
Could you please re'save the file in lower version (mine is 2018)
Message 7 of 10
Just create two different roofs; one on top of  the other. The bottom roof is bounded by the walls and the upper roof has an overhang.  Attach Walls to upper roof.
Message 8 of 10
See attached.
Message 9 of 10
ar999ar
OK, 2 roofs, 1 wall.
It will be the solution
Thank you
Message 10 of 10
Thank you
Great! You're welcome. Mark Accepted Solution.
