Make all mullions continuous
3 REPLIES 3
S.Reise
1025 Views, 3 Replies
S.Reise
Does anyone know how I can make all the mullions continuous? I have a fairly complex curtain wall and I need to model it for renders, so I made the curtain wall with a 10x10cm grid and then modified the mullions, so they have an offset so it shows how it will be built, the problem is that it cuts the horizontal mullions, and I need them all to continue.
I really want to avoid making two walls because I have several walls like this and for changes later it will be very complicated.
3 REPLIES 3
in reply to: S.Reise
If the grid is not angled, then you can create a curtain wall with only vertical mullion and use a curtain wall type with only horizontal mullions for the panels.
They don't work well when the grid is angled though.  In such case, using two separate curtain walls is the simplest way.  Or you can eliminate all mullions and build mullions in a custom panel family instead.
syman2000
syman2000
These type of condition requires custom curtainwall panel and not using mullion. See attached
S.Reise
S.Reise
Thanks to both of you for helping me! really appreciate it.
