Make a roof with different bases
Message 1 of 18
I have a trouble when create a roof with a different based. I want to create a roof as attached footprint, but don't know how to make the higher level as the red circle. Could you please give me a light at the end of this tunnel?
Thanks a lot,
Replies (17)
Message 2 of 18
Different Plate Heights? Easiest way to do that would be to model two roofs and join one to the other
Message 3 of 18
Thanks for your comment.
I tried to make different Plate Heights, but it not work.
I also make two different roofs and joint, but it is very tricky at the hip not really the same.
Could you please show me more clearly,
Thanks a lot,
Message 4 of 18
Share you model here and we can show you.
Message 5 of 18
I'll take a run at it if you want to post the file. I do see the challenge though. I don't think it will the Join/Unjoin Roof tool will work, but you can certainly use the Join Geometry tool.  Clean-up will be a little more tedious.
Message 6 of 18
Yep, I crashed and burned. The only way I could get there was by using Join Geometry.  Lots of cleanup to do on the inside, but ain't she pretty from the outside.
Message 7 of 18
@barthbradley :
Thank you so much, that look pretty good. That is what I want to get.
Could you please show me how. I reckon it should be simple, not too complicate. I'm not a smart guy, so just want make things simple 🙂
Message 8 of 18
It looks like it can be done as one roof. Share the file and we shall see.
Message 9 of 18
Arrgh! I deleted the model.  I'm going to have to recreate it for you.  It'll go faster if you can post your rvt for me to work from.  But NO; it wasn't so simple.  It's a tricky condition.
Message 10 of 18
@barthbradley , @ToanDN :
Thanks for your help,
Please see the model as the link below:
https://mega.nz/#!D55jCIjJ!SRbNWDda15ihGaQBfgrMduxTRgYj-0HHrbhRnErB4D8
Message 11 of 18
Here is one roof but the file is 2019.  I no longer have 2017.  You can open it in 2019, inspect the footprint of the roof and apply the same approach to the 2017 working file.
Message 12 of 18
@ToanDN : That is great for me. But one questions, could we do it with overhang
Thanks a lot.
Message 13 of 18
Thanks a lot.
Of course.  See attached.
Message 14 of 18
Completely different condition than I imagined.   It can be done nicely with one roof.  I can return a 2018 RVT if you need it.
Message 15 of 18
Nice job, @ToanDN . Pardon the "repackaging". I didn't know you were on the job as well.
Message 16 of 18
@ToanDN : you are the Master!
I did nearly the same but can not achieve as your trick. That is really simple.
But a little bit more challenge, how could we deal with two corners below. Could we extend the lower roofs under the higher roof?
Thanks in advance, 99.99% were solved.
Message 17 of 18
Model them as two small roofs by extrusion and join with the main roof.  Then grip extend the fascia to match.
p/s: where in Vietnam are you from?
Message 18 of 18
Wow, how simple it is.
Thank you very much, you are really amazing in Revit,
I born in Middle of Vietnam, studied and worked in Saigon, now live and work in Melbourne,
How about you?
