Make a roof with different bases
Message 1 of 18
I have a trouble when create a roof with a different based. I want to create a roof as attached footprint, but don't know how to make the higher level as the red circle. Could you please give me a light at the end of this tunnel?
Thanks a lot,
Replies (17)
Message 2 of 18
Different Plate Heights? Easiest way to do that would be to model two roofs and join one to the other
Message 3 of 18
Thanks for your comment.
I tried to make different Plate Heights, but it not work.
I also make two different roofs and joint, but it is very tricky at the hip not really the same.
Could you please show me more clearly,
Thanks a lot,
Message 4 of 18
Share you model here and we can show you.
Message 5 of 18
I'll take a run at it if you want to post the file. I do see the challenge though. I don't think it will the Join/Unjoin Roof tool will work, but you can certainly use the Join Geometry tool.  Clean-up will be a little more tedious.
Message 6 of 18
Yep, I crashed and burned. The only way I could get there was by using Join Geometry.  Lots of cleanup to do on the inside, but ain't she pretty from the outside.
Join Geometry of Roof 2.pngJoin Geometry of Roof 2.pngJoin Geometry of Roof.pngJoin Geometry of Roof.png
Message 7 of 18
@barthbradley :
Thank you so much, that look pretty good. That is what I want to get.
Could you please show me how. I reckon it should be simple, not too complicate. I'm not a smart guy, so just want make things simple 🙂
Message 8 of 18
It looks like it can be done as one roof. Share the file and we shall see.
Message 9 of 18
Arrgh! I deleted the model.  I'm going to have to recreate it for you.  It'll go faster if you can post your rvt for me to work from.  But NO; it wasn't so simple.  It's a tricky condition.
Message 10 of 18
@barthbradley , @ToanDN :
Thanks for your help,
Please see the model as the link below:
https://mega.nz/#!D55jCIjJ!SRbNWDda15ihGaQBfgrMduxTRgYj-0HHrbhRnErB4D8
Message 11 of 18
Here is one roof but the file is 2019.  I no longer have 2017.  You can open it in 2019, inspect the footprint of the roof and apply the same approach to the 2017 working file.
Annotation 2019-07-18 164037.pngAnnotation 2019-07-18 164037.pngAnnotation 2019-07-18 164236.pngAnnotation 2019-07-18 164236.png
Message 12 of 18
@ToanDN : That is great for me. But one questions, could we do it with overhang
Thanks a lot.
Message 13 of 18
Thanks a lot.
Of course.  See attached.
Message 14 of 18
Completely different condition than I imagined.   It can be done nicely with one roof.  I can return a 2018 RVT if you need it.
Message 15 of 18
Nice job, @ToanDN . Pardon the "repackaging". I didn't know you were on the job as well.
Message 16 of 18
@ToanDN : you are the Master!
I did nearly the same but can not achieve as your trick. That is really simple.
But a little bit more challenge, how could we deal with two corners below. Could we extend the lower roofs under the higher roof?
Thanks in advance, 99.99% were solved.
Message 17 of 18
Model them as two small roofs by extrusion and join with the main roof.  Then grip extend the fascia to match.
p/s: where in Vietnam are you from?
Annotation 2019-07-18 174659.pngAnnotation 2019-07-18 174659.pngAnnotation 2019-07-18 174644.pngAnnotation 2019-07-18 174644.png
Message 18 of 18
Wow, how simple it is.
Thank you very much, you are really amazing in Revit,
I born in Middle of Vietnam, studied and worked in Saigon, now live and work in Melbourne,
How about you?
