i am having trouble getting a lookup table connected too a family.
I keep getting the message: Inconsistent units and i can't figure out why.
A picture:
left side: the family with the parameters and formula
right side: the .csv file
Hope someone can help me.
Thankyou in advcance.
Nico
Solved by Alfredo_Medina. Go to Solution.
You need to see if your cells are in number that you dont have problem with this the another thing is i recomend you that you use this image like example in the fittings of pipes you have a lot of families with lookup table open one to see how its work.
thnx for the response!
I added the lookup table name parameter.
I don't understand what you mean with: see if your cells are in number
This is what i have now:
@Anonymous
Your "Option" parameter needs to be a length parameter, too. This is the "Lookup Column" which is intended for things such as "nominal size". So, delete that Option parameter, and create it again, as an instance, Length, parameter, not as integer or text and type. And, in the .csv file, change the header of the option parameter to be option##length##millimeters
