loading symbol when insert.
laurensV9CRL
Message 1 of 11
laurensV9CRL
Hellow when i want to insert something to my revit i constantly get the loading symbol on my mouse when i put my mouse in the insert window. It startd when i downloaded revit 25. I get it with every insert: dwg, pdf, family,...
Replies (10)
Message 2 of 11
jay_colc
I have seen a similar issue on this forum and it was related to an Add-in.  Try turning them all off restarting and adding one-by-one to see if you can identify an issue
Manage Tab > Extensions Panel > Add-in Manager
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 11
laurensV9CRL
Didn't work.
Message 4 of 11
jay_colc
Oh well, try this!
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Spinning-cur...
Are the families stored on your PC locally?
Jay Colcombe
Message 5 of 11
laurensV9CRL
no, there are saved on a local server, but i never had this problem before and my colleges doesn't have this problem with the same pc's. i already updates my graphic card multiple times.
Message 6 of 11
jay_colc
On the left hand side in the Folder Pane you have some default folders of Family Libraries (Imperial Lib...) can you open these or does the same thing happen
If you can open these I would assume the issue is not being able to access or have permissions to the folder in the Location you are clicking on in the video.
Jay Colcombe
Message 7 of 11
laurensV9CRL
i can open every file, the loading symbol turns to if i go to a file on my PC
Message 8 of 11
jay_colc
The folder on the Left Hand Pane is a default library on your PC which if you right Click > Edit Places Shows exactly where it is stored
If you can open these folders and insert a Family with no issues I would suggest you have access issues with your Document Folder on your PC as the issue is it is trying to find a Family in a Folder/Location it cannot access hance the Blue Circle.
Can you open any other software and insert something from this folder environment?
Jay Colcombe
Message 9 of 11
laurensV9CRL
yes, i can open files from that location, an other problem is sometimes my windows bar disappears and reboots again.
And when i go to the device manager of windows, my mouse does the same thing (see video)
Message 10 of 11
RDAOU
@laurensV9CRL
  1. When you istalled Revit 2025 did you also install the Updates?
  2. How much free space do you have left on the local drive where you installed Revit 2025? Clean the %TEMP% folder first then check available space left
  3. If you are low on disc space, run windows cleanup and remove the cashed installation files
Might or might not be the case but windows released 2 security patchs in december the first on the 10th and the second on the 22nd. The first caused unstable and unpredictable behavior in certain applications including revit, the send patch fixed it. So you might also want to check updates on both Revit and Windows
Message 11 of 11
jay_colc
I do not think this is related to Revit directly as per the original post on inserting something in Revit and would get I.T. to have a look at your PC and ensure ALL Windows AND Revit updates are installed!
Jay Colcombe
