I have a situation where a modeller is updating a lot of Joinery families for a project which were done "poorly" the first time. She has to load these into 3 models which are then linked into a main model. Is there a way to do this automatically s that all families with the existing names show correctly without having t open each model and reload manually.
Thanks.
Solved by ennujozlagam. Go to Solution.
i don't think that is possible at this moment. Revit has a limitations also. thanks
