linked model not loading
3 REPLIES 3
317 Views, 3 Replies
I have linked the structural model to my model.  I'm trying to upload an updated structural model.  I do a "reload from"...and it shows the loading progress and it stops at 50%.  Then revit is "not responding" and I have to ctrl alt delete and quit revit.  What is the problem.  I have reloaded the structural model before in the same fashion and it was fine.
3 REPLIES 3
Try removing the previous Linked model, and inserting the new one.
The Reload From method may run out of memory. How large is the file?
Hopefully you have set up Shared Coordinates so it will drop in the correct location/alignment.
cheers
I have tried that with no luck.  I do have 3 other models linked as well.  I am able to reload from for each of those models just fine.  Seems to be file specific.  Any other ideas?  Could something be wrong with the structural file?  Does it make a difference whether the linked file is a central or local file?
rosskirby
Have you copy/monitored anything out of the original linked file?  Maybe Revit is looking for something that is no longer there, which usually isn't a problem, because it will give you a warning/notice that something has been removed.  Does the new file have the same name as the old one?
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Forma Design Contest
