link schedule value to sheet text box
BR4K3V6
BR4K3V6
Hi all ,
I have made a schedule to calculate furniture and I was wondering if it's possible to put the result automatically on my printing sheet? Like a linked text box?
Right now I need to put it in manually.
Is Revit supporting a function like this?
Thanks in advance.
RDAOU
@BR4K3V6
  1. Open the sheet
  2. Drag the schedule from the project browser and place it on the Sheet
BR4K3V6
But I don't want to have the whole schedule on my Sheet, only the result included in the title block. Is that possible?
RDAOU
@BR4K3V6
Duplicate the schedule and use a Filter...
Example: You have a sheet with Level 1 Furniture layout
  1. Duplicate the schedule
  2. Add the field/parameter Level (you can make it hidden under the formatting tab if you need to)
  3. Then add a Filter for Level equals to Level 1 and the schedule will be only for those furniture on Level 1
  4. Place that on the Sheet
Repeat the process for other Sheets ...ie: Level 2, 3, 4...etc
BR4K3V6
Thanks! It worked.
