Hi! I can't see an imported CAD file in floor plan. It is visible in Reveal Hidden mode, and the boxes in Visibility/Graphics > Imported Categories are checked but greyed out. No view template applied. What could be the problem?
if it is red or pink then select it in Reveal hidden mode right click and unhide it in view
if you can select it then delete it and instead of insert, use link and check the box for this view only
see if that gives you better options
it might be related to a particular workset that is turned off in that view.
as a rule i try not to insert AutoCAD files if they can be linked
It's invisible whether i link or insert the CAD file; whether it's "view only" or not. All worksets are set to visible. Removed all filters - still invisible.
This file has been handed to us from a different organization, they had worked on it using cloud services, whereas i am working on it locally. Could it be some kind of error related to that?...
open the file in AutoCAD and save it as a lesser version run a purge and Audit
turn on and thaw all layers.
then try linking the new file into a new view in revit
Is the cad file from a linked revit model? by linked view might gray things out.
@jen-sa wrote:This file has been handed to us from a different organization, they had worked on it using cloud services, whereas i am working on it locally. Could it be some kind of error related to that?...
No, as long as you have the file stored locally, this shouldn't be related.
When i receive documents from BIM 360 and i use them locally on our server the links are all set to ATTACHMENT. This will change some things with how links work. So if your linked Revit models are set to ATTACHMENT, i would advise changing them to OVERLAY and see if that helps.
