Linear dimension style's pattern doesn't change
katsanosengineer
Message 1 of 12
katsanosengineer
I try to make the vertical to the object lines looking like small dots but I cannot find any solution. I have tried all (I think) options in the edit type parameter.
Replies (11)
Message 2 of 12
ralphdenhaan
I think you should check out this post: https://forums.autodesk.com/t5/revit-architecture-forum/change-witness-line-type/td-p/10669617
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 3 of 12
ennujozlagam
you need to create new or duplicate dimensions???
Message 4 of 12
katsanosengineer
Hello! I already made a duplicate beforehand, and still nothing seems to do the trick. Perhaps I didn't formulate my question right, but my intention wasn't to change/add arrowheads, but rather the lines that come down from the distance to the chosen object, AKA the "side" lines. My goal is to make a dimstyle close enough to the one I use in AutoCAD: (photo for reference)
 Thank you nonetheless.
Message 5 of 12
katsanosengineer
Hello! Thank you for your response, but my main question remains: is it possible to change the "side" lines, rather than the centerline. Either way if there's a "solution" that requires you to use two centerline distances, wouldn't that just end up being a nuisance...? ( Taking more time and making the file unnecessarily bigger? )
Though I highly appreciate your response, I'm not sure the thread you provided has been helpful.
Thank you!
Message 6 of 12
ennujozlagam
something like this??????????
Message 7 of 12
katsanosengineer
no??????
Message 8 of 12
katsanosengineer
this screenshot is from an autocad layout as a reference to what I want to achieve in the revit sheet
Message 9 of 12
RSomppi
Sorry, that's not possible with a dimension style in Revit.
Message 10 of 12
katsanosengineer
then what would you propose to achieve this result?
Message 11 of 12
RSomppi
I wouldn't. Any solution that I can think of would require additional elements and work like adding lines and adjusting dimensions.
I would make due with what is available.
Message 12 of 12
Omit the Dimension Extension Lines altogether and pull dimension between dotted lines (i.e. Ref. Planes, Ref. Lines, Grid Lines, etc.).
