Change Elevation/Section Viewports to have different default title to Plans
3 ANTWORTEN 3
Nachricht 1 von 4
emily_hill_01
226 Aufrufe, 3 Antworten
Is it possible to have a different default viewport title for elevations and sections only? Currently all viewports when placed on sheets have the same default viewport title. I want the elevations and sections only to default to a different family.
So Plans and Ceiling Plans have the default detail number and sheet number, but the Elevations and Sections have the detail number and then the referencing sheet number.
My current work around is to change elevations and sections manually but this can be time consuming and risks missing views.
3 ANTWORTEN 3
Nachricht 2 von 4
hmunsell
als Antwort auf: emily_hill_01
I'm pretty sure you cant set different Viewport Titles for different View Types by default, but you can change them manually.  In my office the default view title is set to None, which forces the user to pick a view title for the view there placing.
also, using the Title On Sheet view parameter will allow you name them differently than the "View Name" in the project browser.  allowing for shorter named in the Project Browser and more descriptive names in the Title.
Howard Munsell
Nachricht 3 von 4
handjonathan
Hi @emily_hill_01
Thanks a lot for posting your question to the forums!   Has the solution suggested by @hmunsell  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 4
GlynnisVP
I agree with @hmunsell that it is not possible to control the default in Revit. We have implemented this feature for Revit 2020+ in IdeateApps>SheetManager: https://support.ideatesoftware.com/support/help/ideate-apps/ideate-sheet-and-view-tools/ideate-sheet...
