line slightly off axis
Hi, When I draw a line of reference line they are slightly off axis, what should I do? Thanks
Sahay_R
Try this -
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Rina, It is not warning, the problem is the lines that I draw is off axis.
Sahay_R
True. Revit is very intolerant of inaccuracies to a fraction of a degree. Which is why the link that I sent you recommends that you drag one end of the line away from its desired position and then drag it back to where it needs to be.
Rina Sahay
Check your Snaps.
