Line based detail component bug R20
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've tried altering a detail component we have in R20. I added an additional dimension constraint to the start end ref planes, this way multiple of these can be selected in plan and have the lengths changed instead of needing to go 1 by 1.
I've tried searching through the forums, youtube, twitter, no luck.
It does work, however the issue I'm having is that when you update the instance parameter, it appears the drag end doesn't move with it. Also if you nudge the detail component it reverts to it's previous length...
I've tried; aligning and locking the components ends to the ref planes which doesn't seem to change anything, creating a 2nd dimension to the ends of the line with the Bar Length constraint, lock/unlocked in the Family Types window. No matter what, it retain the dot where it was previously if you change the bar length instance.
