Like instances not grouping in schedule
5 REPLIES 5
cbt990
238 Views, 5 Replies
With itemize every instance checked:
without itemize checked:
obviously i am trying to show the total for each material
Revit is amazing
5 REPLIES 5
cbt990
in reply to: cbt990
Itemize does the trick with normal walls but for some reason it doesn't work with parts
Revit is amazing
in reply to: cbt990
Sort by Material?
cbt990
in reply to: ToanDN
Almost worked, except i'm not getting sums for the Charcoal and Glacier White..
Revit is amazing
in reply to: cbt990
Format tab, set Area to Calculate Totals.
cbt990
in reply to: ToanDN
Thank you!
Revit is amazing
Forma Design Contest
Technology Administrators
