Lights and Ceiling issue?
2 REPLIES 2
164 Views, 2 Replies
I'm getting this error message when I'm trying to add a door switch to a wall
None of the created elements are visible in Reflected Ceiling Plan: Level 0 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
2 REPLIES 2
L.Maas
With your family and view settings you are going to place a family in the view. However after placement the object will not be visble due to the parameter/view settings.
This happens for instance when you place a family with default elevation of 2500 mm while your view range is from  0-1500 mm.
While you are allowed to place the element it will not show up in the current view (outside view range).
So it is not a real error but just a warning.
Louis
Please mention Revit version, especially when uploading Revit files.
You can:
- Go to a Floor Plan to place the switch.
- Turn on Floor Plan underlay for the RCP and place the switch from on RCP
- Adjust view range of the RCP to cover you switch (but it may affects other visibility of the view)
Forma Design Contest
Technology Administrators
