Hey people,
i have attached 2 images and those two are different lighting plans done by Revit and Autocad. i just wanted know that is there any method to show up the door cut in revit plan(same as autocad drawing)? <<<lighting plan done by duplicating the floor plan>>>>>
i tried but the all the sofit lightings are 3300 level and my door and window top in 2400 level. i have changed the view range and settings but i cannot find a method.??
if drop the cut plan to 2400 then my lights are missing. if i do otherwise door cut will not show up.
Solved by barthbradley. Go to Solution.
Solved by ennujozlagam. Go to Solution.
What about Underlay?
Wait a minute. Do you mean you are unable to lower the cut plane to cut the doors and show the lights above? Are you in a RCP Plan? Something doesn't compute here.
...never mind. I missed the part where you said you duplicated the floor plan for the lighting plan. You need to create a ceiling plan. If you don't have one already, go to View Tab=>Plan Views to create one.
you can create a plan region in every door and set the view range setting to cut the door. thanks
...or just Clipboard Cut all your wire and whatnot, and Paste it to a Ceiling Plan View.
Yeah it worked but i need the door cuts and light fixtures in plan views not the rcp plans. because there wall lights, floor up light , etc... i have to show them all in the same plan.
