Levels with 2 values
5 REPLIES 5
atejeraLXRTJ
1276 Views, 5 Replies
atejeraLXRTJ
I was searching in the forum but couldn't find an answer to this: I am needing to show my levels and spot elevations with both values, the project level height (0'-0" for example) along with the geodesic height (NAVD or NGVD)
Any ideas how to do it without having to insert a plain text?
Thanks in advance!
Thanks in advance!
5 REPLIES 5
syman2000
in reply to: atejeraLXRTJ
syman2000
Not possible with current project setup. If you want to display both value, you have to create a link.  The link will showcase level move while the current project set as is. See screenshot below as an idea.move level.png
Insert a spot elevation with elevation based on Survey point.
atejeraLXRTJ
in reply to: ToanDN
atejeraLXRTJ
the thing is that in some cases i need to show both values... the elevation from the project base level and the elevation from the survey base level... but the spot elevation family only shows one or the other...
You show a Spot elevation AND the Level. Using a link is fine as long as you don't need to stretch the level lines in views,
atejeraLXRTJ
in reply to: syman2000
atejeraLXRTJ
could you share a screencast or video tutorial how to create that link? thanks a lot in advance!
