I was searching in the forum but couldn't find an answer to this: I am needing to show my levels and spot elevations with both values, the project level height (0'-0" for example) along with the geodesic height (NAVD or NGVD)
Any ideas how to do it without having to insert a plain text?
Thanks in advance!
Solved by syman2000. Go to Solution.
Not possible with current project setup. If you want to display both value, you have to create a link. The link will showcase level move while the current project set as is. See screenshot below as an idea.
the thing is that in some cases i need to show both values... the elevation from the project base level and the elevation from the survey base level... but the spot elevation family only shows one or the other...
could you share a screencast or video tutorial how to create that link? thanks a lot in advance!
