Layer list for Revit to DWG Export
Hello
Where can I get a list of all of the layers that Revit uses when exporting to a DWG file?  I don't want instructions about anything.  I want the current list as it would be if every category was fully expanded.
I want to be able to search and find any layer. Example: S-GRID.  Where is that layer in the listing?  I find it in the final CAD file, but where is it in the export listing?
Nardo
loboarch
The DWG Export setup dialog contains that information.
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-E8443B4B-D55B-4630-BEE3-D2D8628CA17B
Jeff Hanson
Principal Content Experience Designer
Revit Help |
If you want the list as shown above as an editable file, simply browse to the location of the export file. (It will be a TXT file and  maybe located something like [C:\ProgramData\Autodesk\RVT 2018\exportlayers-dwg-ISO13567.txt]
You can then do a search for the layer you need to map or edit.
