Revit ceiling types - possible to shade?
Sahay_R
Mentor Mentor
Message 1 of 10
Sahay_R
On my reflected ceiling plan - some ceilings are required to be shaded to show that they have batt insulation above the ceiling. Since I draw the line at using transparent filled regions for this, I would like to create a ceiling type for this. How do I get the grey fill?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (9)
Message 2 of 10
Revit 2019.  A material can have two hatch patterns.  So you have the foreground pattern for the grid and the background pattern for the solid tone.
Message 3 of 10
Sahay_R
There you go, @ToanDN - making me cry again. Revit 2018 here.....
Rina Sahay
Message 4 of 10
Create Parts from the ceiling, change Parts material or override graphic to solid tone and semi-transparent, set view to Show Both Original and Parts.
Message 5 of 10
Sahay_R
Idiot proof directions, please - when I convert the ceiling to parts, the parts just disappear....
Rina Sahay
Message 6 of 10
Sahay_R
Let me rephrase - i override the display of the Part, set the view to Show Both, and then all I see is the original ceiling because it hides the part
Rina Sahay
Message 7 of 10
Take a bathroom break and come back for a screencast.  Meanwhile I need to go bluffing my coworkers on World Cup 2018 bets.
https://knowledge.autodesk.com/community/screencast/a3f37783-b392-4980-aacf-0d6f5b55ab3d
Message 8 of 10
While you cannot give it a shade, I like to combine a pattern or two...
So you can have the regular dot texture and add in some angled lines or 45 cross patterns...
Message 9 of 10
Sahay_R
@ToanDN - didn't work for me - not sure what I missed -
1) Create Parts
2) selected part - overrode graphic display with solid fill, 50% transparency
3) view displays both
No change. ceiling looks just the same
Rina Sahay
Message 10 of 10
Select both Parts and ceiling and make them 50% transparent.
