Laptop for 3d render and modeling
Message 1 of 27
Is a laptop with 128 ssd with 1 tb hhd enough over a 250 ssd nvme with 1 tb hhd ??
And shall the nvme ssd be my pick over the normal ssd ??
Meaning will I get a better preformace ?
Replies (26)
Message 21 of 27
I can use a pc ... I need a laptop I always work outside and keep running around ..
Message 22 of 27
helios300 vs predator-15
Are these what you are looking at?
Message 23 of 27
Yes ... but the specs are limited to my price point
The helios has the core i7 7700
The 15 i7 7600
And both gtx 1060 ... one with 250 ssd nvme ( the helios ) and the other with a 128 ssd * both coupled with a 1tb hdd *
Message 24 of 27
To sum it up"
- Helios: better SSD, lighter, worse screen, $600 cheaper
- Predator: worse SSD, heavier, better screen, $600 more expensive
If other things equal then go with the Helios.  You can stick several $100 bills to the edge of the screen and you will feel it is a better one.
Now of course, having a dedicated box to render 24/7 and a lightweight laptop to lug around is a valid idea.  Remember that when you start a rendering, you cannot use the computer for nearly anything else no matter how powerful it is.
Message 25 of 27
To add up for it the helios also has the core i7 7700 and the 15 has the i7 6700
Message 26 of 27
amorap
I agree. Render is a very demanding task.
But you can limit the resources used by any program in Windows 10, for example you can limit the number of cores that will be used by 3d Max, in order to keep enough power for other apps.
The way to do this is:
1- Open your apps
2- Open task manager
3- Open "details" tab in task manager
4- locate the app you want to limit the resources
5- Right button to invoke the contextual menu,
6- Choose "set affinity"
7- Select the cores that you want to be used by the app.
regards from Spain.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 27 of 27
amorap
Related to this topic, today I will receive my new laptop
https://www.gigabyte.com/Laptop/AERO-15#kf
Maybe the hardware specs matchs yours.
Regards.
Augusto Mora
