Keynote Schedule that includes Sheet name and number
Message 1 of 8
Has anyone ever created a keynote schedule that would incorporate the sheet name and number in it? I would like to be able to make it so I can sort by sheet number then sheet name then keynote number. I know that you can see this information if you are using keynote manager but you can't put that on a sheet.
Replies (7)
Message 2 of 8
You know you can Filter Keynote Legend by Sheet, don't you?
Message 3 of 8
Yes... That applies when you put that schedule on several sheets. I want to put the schedule on a sheet and have it list each sheet and each keynote that is on that sheet.
Message 4 of 8
I basically want to know if anyone has been able to add the sheet name and sheet number fields to the keynote schedule successfully.
Message 5 of 8
So you want a contractor to switch between sheets then go back to the legend sheet and then back to the view sheet....back and forth...  You don't like your contractor's do you?
Message 6 of 8
Strictly for in house use.  Lot of young designers writing excessively long notes. Mostly for a learning tool.
I have worked with an architect that made us place the keynotes on a sheet in the front of the set, sorted by project and not have them on each sheet. He didn't like his contractors.
Message 7 of 8
Actually, I've 11x17 plan sets this way.  In AutoCAD. Don't remember doing it in Revit though.
Message 8 of 8
Corsten.Au
lot of people use " NOTE BLOCK " to identify unique Scheduling per different sheets..
Noteblock can schedule different symbols.. as long as you place
Unique ( Identifying ) symbol, on plan, some view which is on sheet , and create
a parameter ( Text, Sheet number, Sheet name ), you can create a Note block schedule to
place on from Cover page etc..
for example..
A - Count
B - Symbol type
C - Custom Parameter, this wont pick the sheet number automatically, but just need
to assign .. in this example I have written Sheet number and name...
Best luck
Corsten
Building Designer
