Joining slabs together
7 REPLIES 7
Message 1 of 8
parkside125
935 Views, 7 Replies
Hey everyone,
I was wondering if there's a way to 'join' slabs together seamlessly. The thinner lines are separate slabs that have been modelled. When I join them I can still see a thin line running through. I've tried changing the lineweight to invisible but that doesn't really help.
Labels (4)
7 REPLIES 7
Message 2 of 8
in reply to: parkside125
the line must be coming from something else.  You're not in Wireframe; are you?
Message 3 of 8
parkside125
in reply to: barthbradley
Thanks for replying. No, I'm in hidden line mode
Message 4 of 8
if the 2 slabs are joined - and they are the same material - then you shouldn't be seeing any linework at the union. Isolate the slabs in the View.  See any linework?
Message 5 of 8
parkside125
They are the same material but still not joining up properly
Message 6 of 8
That's what you see when the 2 slabs are isolated in the View?  They're System Families? Not In-Place?
Message 7 of 8
BIM-CONG
I see there are three elements in the isolated view you posted, whether you forget to modify the material of  the thicker floor which joined with the others?
You can copy the elements into a new file and attach it here, so we can test it further.
CONG XU
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
- BIM THE FUTURE -
Message 8 of 8
RDAOU
@parkside125
Floor elements do not always clean join. There are various situations where they do leave that hairline joint even if they are of the same material.
There are several ways to workaround that to get a clean join but since you have solved your case you should be all good to go
Forma Design Contest
Technology Administrators
