I have been experiencing this error for some time now and can't find a solution. The shadow in the 3D view appears to jagged and pixelated. How do I overcome this problem? Attaching the screenshot of the error below.
Solved by aRcHiTeCt.JM. Go to Solution.
... hi @Pushkraj12
.... that happens from time to time
... try to delete and create a new 3d view from the same angle
.... that will fix the issue
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
…. hi @Pushkraj12
… then... it most provably be the hardware acceleration
… go to file
… open options
… there go to hardware
… uncheck the hardware acceleration
.... Be aware that disabling hardware acceleration, while it can fix most of the graphic glitches but also degrade Revit performance, especially when you working with 3d views, orbit, shade/realistic visual styles.
Try to update your videocard driver if possible, or replace it with a compatible one if updating the old card driver is not an option.
aRcHiTeCt.JM
REVIT EXPERT ELITE
