Jagged shadow edges in 3D view
Pushkraj12
Pushkraj12
I have been experiencing this error for some time now and can't find a solution. The shadow in the 3D view appears to jagged and pixelated. How do I overcome this problem? Attaching the screenshot of the error below.
aRcHiTeCt.JM
... hi @Pushkraj12
.... that happens from time to time
... try to delete and create a new 3d view from the same angle
.... that will fix the issue
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Pushkraj12
Tried this solution,the problem still persists.
aRcHiTeCt.JM
…. hi @Pushkraj12
… then... it most provably be the hardware acceleration
… go to file
… open options
… there go to hardware
… uncheck the hardware acceleration
.... Be aware that disabling hardware acceleration, while it can fix most of the graphic glitches but also degrade Revit performance, especially when you working with 3d views, orbit, shade/realistic visual styles.
Try to update your videocard driver if possible, or replace it with a compatible one if updating the old card driver is not an option.
aRcHiTeCt.JM
REVIT EXPERT ELITE
Do you have CAD link/import that far from the origin? Turn off Imports category and see.
evlCTSRS
Community Visitor
Community Visitor
same problem, no solution found yet
