I can’t install revit 2020 in my computer.
Why? I have more than the required settings.
Please help me understand. Thanks.
Windows 8.1
Gtx 1080
32 ram
Ssd 512GB
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
…. Installation Changes in This Release
…. Revit 2020 will not install on systems running Windows 8 or 8.1.
… you need to upgrade to windows 10
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
There is a way around it...but in the time to modify the file it is probably cheaper to just purchase and install 10...
Also it isn't supported by Autodesk....so any issues you have you will be on your own.
You can install Revit 2020 on Windows 8 and Windows 8.1. Can only be installed via Autodesk desktop app, there is no silly protection in this installation for 2020.
