It's a right handed world
AzWoodWarrior
AzWoodWarrior
Is there a way to switch the ESC command with the ENTER key? It wouldn't be a problem if I were right handed, but having to reach across the keyboard is getting a little old. Plus, I'm switching from autocad and it's a hard habit to break.
RDAOU
Remap your Keyboard
MostafaElashmawy
You can't change it to "Enter", but you can assign it to any other near button.
For example : "\"
while opening any project click the shortcut "KS"
Here you can edit any shortcut. select Modify which has a current short cut = "MD" and add the new shortcut.
Mostafa Elashmawy
You're kidding; right? No pun intended, Lefty. What "habit" are you trying to break?  The ESC and ENTER Key is always located in the exactly the same spot on the keyboard, no matter what software I'm running.
