I am trying to figure out why, the mullions on my windows do not show up. I clicked on the window, and it shows the mullions but on the revit file they are invisible, and they are not hidden. The material is there, so that material should show up on the window.
Here in this picture, it shows what is highlighted.
Solved by barthbradley. Go to Solution.
@jgarciacorpus69 wrote:I see the mullions thanks! But I want to fix another issue with the wall 😞
How about we just help you put out one fire at time? Is the muntin issues resolved? If so, then mark the appropriate posts as Accepted Solutions (heck, mark 'em all as Accepted Solution), and then start a new thread with a new question. Sound good?
