is there option/work around to take developed sections like this in revit?
Message 1 of 17
I need to take developed sections like this in revit?
please reply soon, this will be very helpful. Thanks you.
Replies (16)
Message 2 of 17
RDAOU
@Anonymous
  • If you mean if it is possible to detail sections in revit, the answer is yes.
  • If you mean that you have that section modeled in a different CAD software and you want to bring/import it into Revit...the answer is also Yes
I would elaborate but I'm just not sure what exactly is being sectioned  in the image you posted.
Message 3 of 17
@RDAOU  Thank you so much for your swift reply.
I need to take a section to see what things are on all walls (5 wall elements in that image). Is it possible to do that with one section?
Message 4 of 17
RDAOU
@Anonymous
In principle, yes. Section in Revit reflect the components placed in the model...If all the components are there, then your section would look just as you expect it to look like 🙂
Taking the image you posted as an example:
  1. Walls in Revit have layered structure so yes you would be able to see all those layers in 1 sections
  2. The Studs you have at the corner, these would be a separate element(s)/component(s). EIther 3D components or 2D components.
    • If you have placed 3D components in the model, they will show in the sections automatically
    • If you have used 2D components in the plan view to represent the studs, then these will not show in the section (2D components are view specific so you would need to detail these again in section)
  3. The arrows which you have there...These can be a Line Based detail items placed on the section
Message 5 of 17
Thanks for your reply,
Our question is, How to get section view  like red line, that means ,need to see 4 objects on walls.
Can you please send any screen cast/steps image to get clear procedure?
Message 6 of 17
You can split segments a section line to create the jog around the walls like what you show.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-D...
Message 7 of 17
RDAOU
@Anonymous
You cannot do that with one section line (to show 5 walls)...
  • You can use the section(s) showing the 3 front walls (single or multiple)
  • Place the lateral sections and Overlay on sheet in a way to show it unwrapped
Message 8 of 17
@RDAOU , @ToanDN  Thank you so much for your reply !
I have take section as shown in first image. So getting view like 2nd image.
But, we need to get a section as developed view as shown below! Is it possible?
I have attached revit file as well for your checking and getting easy solution. Thanks in advance.
Message 9 of 17
RDAOU
@Anonymous
Read previous reply...you cannot unwrap in revit...you need to place several sections and the Overlay on the sheet
Message 10 of 17
RDAOU
Message 11 of 17
@RDAOU  Thats awesome. This is what we expected from Revit.
Can you please send screen record of initial steps of how you created section lines & merged it together (some more detail) on sheet?
Your answer will be our solution which is very important now.
Message 12 of 17
RDAOU
@Anonymous
I can share with you the Revit file for you to look into it...
(PS: have to admit I used dynamo to align crop region of each section to Reference planes but you do not need that, it can be done manually)
See attached .rvt
Message 13 of 17
@RDAOU  Again Thank you very much.
Your answer is very helpful. You have been supporting a lot.
Can you pls share that dynamo which will speedup our boring Revit work?
Message 14 of 17
RDAOU
Shouldn't that be a topic for a new post?
Message 15 of 17
@RDAOU
Ok, I will close this query with accepted solution and I will create a new post, Can you share it there?
Message 16 of 17
RDAOU
@Anonymous
That sounded like a conditional statement!!! The purpose of this forum is to help other who are putting effort from there end ... not do the exercise from A to Z. You are the one on payroll ...
So you do not need to accept solution here. And if you decide to post your dynamo question as a new thread, I might consider helping if I sense that you have tried to put some effort or do some research but not able to get something to work
Message 17 of 17
@RDAOU  Thanks for your great support !
My apologies for being wrong in your view. I would not like to put conditional statement.
I asked about dynamo because , i am not familiar in dynamo, And its needed in short time.
